Correct coolant alum rad. - NCRS Discussion Boards
  • Bruce M.
    • December 2, 2010
    • 14
    I have a 1960 with alum rad. and need to know what to put
    in it so corrosion does't take place.
    Thanks,Bruce
  • Jim D.
    • 2882
    Re: Correct coolant alum rad.
    Zerex G-05.
    • Bruce M.
      • December 2, 2010
      • 14
      Thanks, should it be 100% coolant or mixed with water?
      Bruce Marler
      • Jim D.
        • 2882
        Bruce Marler
        50/50 with distilled water.
        • Larry M.
          • January 1, 1992
          • 2688
          I agree...............but G-05 is now also sold as pre-mixed, so no additional water is necessary. Be sure you know the type you are buying.
          The above message was learned from personal experience.
          Larry
          • Richard C.
            • July 31, 2001
            • 144
            Would the zerex g-05 work in a brass/metal rad?
            • Dick W.
              • 10483
              Works in almost anything. The only thing that I would have reservations about using it in would be HD diesel engines.
              Dick Whittington
              • Larry M.
                • January 1, 1992
                • 2688
                Dick:
                According to their printed technical information, Zerex G-05 contains the heavy duty additive package needed for diesel engines. (Cummins and Ford are specifically mentioned as approved and endorsed).
                Larry
                • Larry B.
                  • October 21, 2010
                  • 254
                  Anyone know a major retailer that carries Zerex? I went to a couple local FLAPS and they did not have it. Thanks
                  • Dick W.
                    • 10483
                    Autozone, Advance, NAPA, Carquest, Wally World all have it here
                    Dick Whittington
                    • Larry M.
                      • January 1, 1992
                      • 2688
                      Agree with Dick (yet again).
                      I buy mine from NAPA.
                      Larry
                      EDIT: The light green or golden Prestone antifreeze is also very good. Use it if Zerex G-05 cannot be obtained. Also G-05 is sold by both MOPAR and FORD under their own labels. I can also provide these part numbers if all else fails.
                      California MUST have something similar to use.
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        Coolant alum rad.; Amazon.com w/ free shipping
                        Larry,
                        I'm pretty sure you can get Zerex G-05 on Amazon.com, either the concentrate or 50/50 pre-diluted, and if the total is over $25, it will ship right to your house for free.
                        Gary
