Re: 1965 3030 verces LT1 cam
My question is to Michael Frost, if you have a 340hp 63 car why are you using the 30/30 over the 097. With the other related 63 parts why not use the original camshaft.
I would spend my time maximizing the compression ratio with the head gasket/quench distance and keep the engine componits original spec.
That's one reason why these over cammed engines need to idle so high because they have no dynamic compression ratio. Combine that with close ratio and 355-370 gear..
I say to each his own!
