Where to get correct brake drums? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I have a 1960 restoration and per the TIM & JG the front and rear drums should have the spring around the brak drum.
    I have attached a picture of what I think may be an original off my car. This one has a part number GM 3752623 19. It has a very obvious raised area that creates a groove for the spring (red arrow in the picture).
    I have looked at replacement drums on Corvette Central and Paragon that have the springs, but I can't tell from their web site if there is a distinct raised area above the spring.
    Does anyone know if these drums are correct, or know of a source for correct drums? I need replacements for my car.
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Where to get correct brake drums?
    Without the groove, brought about by the "raised" area, the spring will not stay in place. I bought replacements for my 63 and they did not have the groove. They also would not align with the shoes properly, so I had to cut my originals.
    Stu Fox
    • Donald H.
      • November 2, 2009
      • 2580
      Guess I'll keep looking
      Don Harris
      • Dennis C.
        • June 30, 2002
        • 884
        Don,
        I purchased drums from Paragon for my 61 and had no problem installing the drum springs. If I recall, they sell two different drums, one for the springs and one without.
        Dennis
        • Donald H.
          • November 2, 2009
          • 2580
          Originally posted by Dennis Crupi (38211)
          Don,
          Dennis
          Dennis, did your drums have a groove for the spring? I saw that Paragon had drums with springs, but I could not see that there was a distinct groove for the spring.
          Don Harris
          • Dennis C.
            • June 30, 2002
            • 884
            Don,
            Yes, they did. I purchased the drums and then the springs and installed them myself.
            Why not call and speak to them about the drums you are interested in?
            Dennis
            • Chris H.
              • April 30, 1990
              • 817
              My drums have part number 3752623 in them. Not sure if that is correct but I believe it is.
              My old interchange manual says 51 - 56 chevy are the same but perhaps they did not have the spring ring?
              Do a google search on "3752623 drum" and see what comes up
              Hopefully someone can confirm the above.
              • Donald H.
                • November 2, 2009
                • 2580
                I have one drum with that same part number. I assumed it was a correct GM part. I did google the part number before. Got a hit for a couple but there is only a listing of parts when I pull up the hit. No contact info.
                I've found some on ebay, but never know what to expect when I buy used parts from folks on ebay. Especially something like a brake drum which can look decent, but not enough surface left to turn to get a good braking surface.
                Don Harris
