67 differntial mounting bracket - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    should the front bracket have the reinforcements or not.
  • Joseph T.
    • March 1, 1986
    • 169
    Re: 67 differntial mounting bracket
    No- Not for 1967
    • Rich P.
      • January 12, 2009
      • 1361
      To clarify the 67 has washers welded on the one hole but not the plates welded on both holes.
      Rich
      • Wayne M.
        • March 1, 1980
        • 6414
        Keith -- I'm not a '67 expert, but I believe you should have the forward reinforcement washers shown in this TSB, and released (with washers) as # 3868799, in production. I believe it wasn't until the C3 era that they added the plate to each side of the bracket, to support both forward and rear bolts. This latter design also had the forward lip of the bracket removed. Others will probably revise my description, if I'm not correct.
        • Keith B.
          • March 7, 2008
          • 928
          Did the late 65 to 67 have the washers
          • Rich P.
            • January 12, 2009
            • 1361
            65-68s had the washer welded on the front.
            • Keith B.
              • March 7, 2008
              • 928
              so will the original bolts be long enough to fit with the washers welded on?
              • Rich P.
                • January 12, 2009
                • 1361
                Yes the original front bolts is the same as the trailing arm pivot bolt. Early headmarkings are P, SB, and SBC.
