1. There are no blown fuses.
2. There is no visible damage to the wiring under the dash.
3. Pulled the cover off the regulator and there is no visible scorching or burnt smell inside.
4. Removed the distributor shielding and there is no apparent damage to the wires to the coil or the distributor.
5.
6. Decided to try cranking it. The car cranked and runs fine. Harness did not get hot although I did not run it for more than 5 minutes (and the heater was off).
alternator battery terminal.
b. Re-started and ran well several times while checking.
that before.
