Stainless Restoration - Classic Stainless - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I am about to send my C-2 hard top trim to have the scuffs taken out and get it polished. I tried it myself but just do not have the right equipment to get a good result. I am planning to use Dave at Classic Stainless. He has an ad on page 34 of the current Driveline. He seems to know his stuff in talking to him. Has anyone had any experience with him?
    Thanks.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Stainless Restoration - Classic Stainless
    A $69 Harbor Freight buffer and a couple fo different types of compound is all you need. I'll bet your problem is that your parts still have the flash chrome on them. Chrome is VERY hard and will not easily buff off.
    Strip the chrome with a 15 minute swim in a muractic acid bath and try again. You will be pleasantly surprized how easily your parts will buff out after the chrome is gone.
    tc
    • Larry T.
      • May 15, 2007
      • 404
      How well will the stainless hold up without tarnishing/discoloring once the flash chrome is off?
      • Stephen B.
        • August 31, 1992
        • 261
        Stainless after polishing will out live the pyramids, is that long enough ? You can polish your own stainless,but it takes some patients,and caution.
        There are some safety issues for you and your stainless. Like most restoration jobs it requires some special tools ,proper instruction,and getting your hands dirty.Good luck.
        Stephen Barrett (21558) 59,66,71,73
        • Anthony P.
          • June 27, 2010
          • 485
          You can definitely do it yourself, but it takes time.
          I have been polishing my 62 trim the past 3 weeks (hardtop, plus all of the other trim) and it is coming out great. I went a little overboard with a nice Eastwood dual speed 10" buffer and all of the goodies The pieces that I have done so far look like mirrors. I have even worked out some significant dents that you will not even know were there.
          That was a good tip on the muriatic acid, I have been using an emery buff to work off the flash, or for rough pieces, 320->400->600 grit sandpaper then emery followed by the next 2 stages.
          My justification for spending the extra on the equipment was, it would have cost me lots more to send it out, and now I have a nice buffer to use when needed, such as when I need to polish that 1 stainless screw, I can.
          Tony
          • Larry T.
            • May 15, 2007
            • 404
            Are you planning to have it re flash chromed when done polishing?
            • Tracy C.
              • July 31, 2003
              • 2739
              Larry, I had mine reflashed. I used Areba Chrome, but Rick Applegate sold out. I think the person who bought the shop also does this. Here is a picture with and without. You will notice the difference most on overcast days.
              • Jim T.
                • March 1, 1993
                • 5351
                Tracy when you used Areba Chrome where was it located? It was once in Jackson, Tn, but not now that I know of.
                • Joe R.
                  • May 31, 2006
                  • 1822
                  Tracy,
                  Did you mean to post some pics?
                  Joe
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Yes I think it was in Jackson Tennesee. I think the shop is in the same spot only under a new name. I've seen posts here, and I think if you searched the archives, the information would surface.
                    tc
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      Originally posted by Joe Raine (45823)
                      Tracy,
                      Joe
                      Only the one pic... If you can't see the difference, turn the brightness down a tad on your monitor.
                      • Scott M.
                        • January 1, 1996
                        • 216
                        I always thought Areba just handled parts for Dans Chrome and Polishing in Adamsville, TN, whatever the case, the parts I got back were excellent and at a great price.
                        • Jerry C.
                          • November 1, 1995
                          • 741
                          Dave has done two C-1s for me and does excellent work.
                          • Paul J.
                            • September 9, 2008
                            • 2091
                            tc
                            Tracy, how does the Harbour Freight buffer perform when you put pressure on it? Does it have enough torque to keep working? The Baldour buffers that Tony mentioned have enough torque and are excellent, but they are very pricey.
                            Paul
                            • Stephen B.
                              • August 31, 1992
                              • 261
                              Gentleman
                              Can anyone give an explanation why GM would make something out of stainless and then ad to the production cost by plating a material that will outlast the pyramids.Mild steel would have been cheaper and far easier to form. It still could have been cheaply plated.I'm doing a 59 hardtop right now and I can tell you after I put the work necessary in my moldings to buff and repair their not getting plated. Makes absolutely no sense.They didn't plate any of the exterior moldings.
