Coil Spring Id - NCRS Discussion Boards
Coil Spring Id
  • Joseph M.
    • June 30, 1999
    • 334
    Coil Spring Id
    How can I determine if the coil springs from my 67 BB non air coupe are the originals? The ID tag is long gone. Thanks.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Coil Spring Id
    Joseph,
    Original springs were a varible rate (coils at top were spaced closer than the coils at the bottom..see picture) If you have a pair of calipers that can measure the wire thickness, then post it here along with the overall length and number of coils.
    Someone should be able to ID what you have.
