65 326 water pump hub spacing info - NCRS Discussion Boards
  • Peter J.
    • September 30, 1994
    • 586
    Re: 65 326 water pump hub spacing info
    I only happened to have one because I had read somewhere, maybe in the Restorer about pulley failures and that reinforcement was the quick fix from Chevrolet back in the day so I thought it would be a good idea to use one and happened to notice it was the perfect thickness under the W/P pulley to fix my alignment and spacing problem. Sounds like I might need to look at a 67 AIM.
