1953 Soft Top - NCRS Discussion Boards
1953 Soft Top
  • Jim P.
    • May 31, 1974
    • 47
    1953 Soft Top
    Is there supposed be a stamping of some sort, like a date or manufacturers number, on the rear plastic window of a 1953 soft top?
    Jim
  • Philip C.
    • December 1, 1984
    • 1117
    Re: 1953 Soft Top
    Hi Jim the short answer is yes, if you need to know more I'll take a look. Phil 8063
    • Jim P.
      • May 31, 1974
      • 47
      Re: 1953 Soft Top
      Phil, I'd appreciate it if you could give it a look see. I guess I should have added that I've looked everwhere on mine and can't find anything. I've had it in the bright daylight, in the dark - back lit and front lit and everything inbetween. I'm just curious as to what it might indicate.
      Jim
      • Gary H.
        • June 30, 1980
        • 155
        Re: 1953 Soft Top
        You will find the answer to your question in the 1953-55 Judging Guide.
        Exterior / 4. Soft Top / Rear Window......Gary
        • David B.
          Former NCRS National Judging Chairman
          • March 1, 1985
          • 219
          Re: 1953 Soft Top
          Jim
          Jim, you have a PM.
          Dave
