Half Shaft French Lock Tabs? - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    This a minor detail but nevertheless, the 66 JM states; typically, BOTH of the "tangs" on the French locks are bent over the bolt head whereas the 66 Assembly Manual states; bend ONE tab tight against flat on bolt.
    Seems to me that the AM makes more sense because a hex head bolt does not have a flat 90 degrees apart to accept the lock tab correctly.
    Again it's very minor! ------ just trying to do things correctly.
    Thank you,
    Ralph
    Re: Half Shaft French Lock Tabs?
    Ralph -
    I can't imagine an experienced Chassis judge taking a deduction if both tabs aren't bent.
    • Ralph B.
      • July 30, 2008
      • 178
      Ralph -
      Thank you !!!!!
      Ralph
      • Michael W.
        • April 1, 1997
        • 4290
        Possibly by 'both' the writer meant one at each of the two ends ie- both ends.
        • Ralph B.
          • July 30, 2008
          • 178
          That's most likely the correct interpretation.
          Thank you,
          Ralph
