does the rear valence panel attach with bolts or phillips head screws, i have been told are correct can someone help, which is correct for a 1966 coupe may build date. jack
1966 rear valence panel bolt or screw
Re: 1966 rear valence panel bolt or screw
Jack,
7/16" head special thick and wide captured washer. Headmarking EL, ELH with 2 or 3 circles.
Rich- Top
One last picture to show the side.Attached Files- Top
Jack, These should be called out in 66 AIM Section 1, sheet F3 dated 5/16/66
Believe the pn is 9418710 however you will need to check since I have marked it two different ways. Have pictures of that pn if needed and if its the same for the 66
Another one will be the two lower screws, lw, & nut. So check the pn for these also!
Picture in last post did not work here it isAttached Files- Top
