1957 Corvette Wheel Cylinders - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1229
    I would like to know if the wheel cylinders are a judged item for a 1957 Corvette. Are the wheel cylinders #'s judged also or not and what about the bleeder screws? Thanks!
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1957 Corvette Wheel Cylinders
    wheel cylinder cast # , to be visable to the judge, would require removal of drums which doesn't happen during ncrs flight judging. when it comes time to sell, prospective buyer may want to see the cast #'s. as far as the bleeders go, there was a small recessed hex head bolt that threads into the bleeder itself. gotta remove the small bolt to bleed the brakes. as i recall, the bolt has a captive external tooth lock washer as part of its makeup. gary pronesti has the correct bleeder with the bolt. reasonable i might add and no, i have no commercial interest in mr pronesti's operation. he's justy a good friend, albiet half nuts . mike
