Tach drive generator gear lubrication - NCRS Discussion Boards
  • Mike T.
    • August 31, 1979
    • 118
    How do I lube the gears in the drive unit where the tach cable hooks up?
    What kind of lube do I use?
    Thanks guys.
    Re: Tach drive generator gear lubrication
    Thanks guys.
    Mike -
    I used Lubriplate "A" (white lithium grease) in all of my C1 tach drive gearboxes, never had a problem. Remove the box from the generator, take it apart, clean the parts, lube, put it back together, and re-install.
    • Mike T.
      • August 31, 1979
      • 118
      Thanks John.
