Hello Again,
While crawling under my latest aquisition (1967 327 coupe) I discovered that it looks like the relay rod is bent. The LH inner tie rod end has rubbed against the lower control arm and broke the grease nipple off the tie rod end. There are tell-tail marks on the relay rod that lead me to believe that perhaps a tow hook was tightened up on the relay rod. I do not see any other signs of damage in the frame or the control arms.
I was hoping the collective experts could provide an opinion for replacement. Existing relay rod is 5 hole style (car does not have PS). I see that there are newr versions, thicker versions, big block versions, 3-hole versions, etc.
What would you recommend? Find a used GM original exactly like what I have? New manufacture replacement? Upgrade to larger diameter/big block? Etc.
Thanks in advance.
Sincerely,
DAP
Thanks in advance.
Sincerely,
DAP
