Headlight wiring harness - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    1965 corvette big block headlight wiring harness that runs down left fender well, does it go over te top of core support , I know it runs underneath the header bar, but i dont know how its routed threw the core support.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Headlight wiring harness
    Brenton -- over the rad support at the corner. Pic is of a '65 air car. HL harness is the upper one shown, but all '65 (and other C2's) have the headlight harness on the left side.
    • Rich P.
      • January 12, 2009
      • 1361
      Wayne, nice picture as always This is a TI car also?
      Rich
      • Dale M.
        • December 27, 2007
        • 386
        I thought it might be good to post a picture of my '64 with the hood off. I have just been rebuilding my headlight motors and buckets. I just installed a headlight harness. There is a nice little area at the end of the radiator support for the harness to pass. This is not a hard task. I happen to get my harness from Eagle Wire Products now located in Ohio and I am very pleased.
        • Philip C.
          • December 1, 1984
          • 1117
          Rich
          Hi guys, Rich, Wayne showing off His solid state voltage regulator. Dale you need a clip to hold your harness to the radiator support, it clips on the side of the support about five inchs down. Phil 8063
          • Wayne M.
            • March 1, 1980
            • 6414
            Rich, Phil -- yup ; but sharp eyes would have seen that it's a 1111678_B, and not the correct 1116368 for '65 L79 or L76 w/C60 and K66. I've also got 3 NOS of the 368's (dated 4H -- correct for my Nov. '64 car, and a 4K and a 6A).
            The three TI amp mount (empty) holes can be seen on the rad support; been at least 30 years since there was something functional there.
            Problem is, I accumulate this stuff but drag my rear when it comes time to install . I'm a junior member of the NCPS -- National Corvette Packrat Society; and we all know who the president is .
            • Dale M.
              • December 27, 2007
              • 386
              Phil, thanks for catching my missing clip. It must have been omitted when someone a few years ago replaced the radiator support. I just want to clarify, this clip is on the front side of the radiator support? I need to look to see if there are any holes. I also just discovered that I am missing the horn wire clips where it runs across the front of the radiator.
              • Philip C.
                • December 1, 1984
                • 1117
                Hi Dale, the clip pushes in on its side onto the edge of the radiator support, there are no holes for it. Phil 8063
                • Dale M.
                  • December 27, 2007
                  • 386
                  I got it, Thanks for finding this omission. Dale
