64 Carter WCFB
I purchased 64 327 4-sp with "300" HP. However it has a Carter WCFB carb 6-1672. Link on passenger side has 446, linkage on driver side to fluter has 263. Bowl has 0-1465. Foil has:
3646247
369 S
A4
Manifold has 3844457 GM8
1) Is it possible this originaly had 300 HP?
2) History is that engine components are all original but block was replaced. I don't see a block # on the right or left front, just two flat areas where maybe one should be. Where should I look for a block number?
3) Previous owner said it has a non stock cam. What part# or specs can I use to install a cam that would enable 300 or 350 HP? What other parts would be needed? Value wise, should I just leave it alone? Thanks, Craig
3646247
369 S
A4
