I have an original early 67 day/night inside mirror that I've partially restored. The mirror is the early version with the square knob. My knob has significantly faded from the sun. The color is an off white color. During the resto I did not need to remove the rubber although it was faded to a light tan color. I left this alone because it is original. Since the rubber was not removed I can't tell what the original color of the knob is looking inside. I've been told that the knob is carry-over from 66 which was black. The 67 TIM says the lever (later version after VIN #2500) is gray. Is it fair to say the knob is gray also or should it be semi-gloss black like the 66? I noticed the early repo's are gray.
thanks,
Dereck
thanks,
Dereck
