We don't have ballast resistors on 70's, so one of the 2 wires that goes
to the positive side of the coil must be a resistor wire.
Both of the wires are covered in a white insulation type material, (similar to what the old cars had for the wire that lead to the temperature sensor in the intake.)
A section of one of the wires (the one that goes into the wiring harness-not the one that goes to the starter solenoid), has some brown to black areas on the white insulation material. It looks like it got too hot.
I touched the wire, and it was hot-almost too hot to continue holding it.
The hot area is right next to the coil. I touched the wire 8-10 away from the coil and it didn't feel hot.
Is this normal?
Is this normal?
