'61 FI Total Timing Specs - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    Where should my total timing be on my '61 stock FI? I have my '65 set at 36* @ around 3000. Should the '61 be the same? Thanks, Larry
    Re: '61 FI Total Timing Specs
    Larry -
    34*-36* total timing should work fine for you. Your 1110914 distributor centrifugal advance spec is 0*-2* @ 1200 rpm, 1.6*-8* @ 3900 rpm, and (max) 20*-24* @ 6000 rpm. If you map your advance curve and it matches, initial timing of 10*-12* BTDC should put you in business.
    Do you know for sure that your '65 isn't advancing any further above 3000 rpm? You need to rev it up until it stops advancing to confirm the timing map.
    • Don H.
      • December 1, 1981
      • 1482
      What HP Fuel car? I think they still had two in 1961. Don H.
      • Larry B.
        • October 21, 2010
        • 254
        Sorry Don 315 HP. Larry
