R&R Time for a 1974 Front Pinion Seal - Differential - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    Does anyone know the R&R time for the differential front pinion seal? I do not have a lift and cannot crawl under cars like I used to so was thinking of taking the 1974 to a local GM dealer that maintains my DD (newish Impala). But I do not want someone there to experiment/learn on the job so I need an approximate flat rate time. I believe the seal is only about $20.00 for a quality (non-Chinese) version. I was thinking GM itself or NAPA as the source. The local NAPA is very good with some real oldtime "car people" working there.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: R&R Time for a 1974 Front Pinion Seal - Differential
    Paul,
    If you would like the adventure of crossing the border into a foreign country, I can recommend an independent shop that many of us use for the type of work you're considering.
    • Paul L.
      • November 1, 2002
      • 1414
      Thanks Mike. That's a bit of a long trip for what appears to be a fairly routine repair but we shall see come April. I'll speak first with a friend (Service Advisor) at a local Chevrolet dealer to see if there are any grey-hairs left on staff.
        • 43193
        Paul-----
        I would say that for someone who knows what they're doing, has the proper tools, and can raise the car on a lift, the entire operation should not take longer than about 1 hour.
        • Paul L.
          • November 1, 2002
          • 1414
          Paul-----
          Thanks Joe. I figured about two hours. The driveshaft has to be dropped so why not replace the TH400 end seal as well.
          • Gary R.
            • April 1, 1989
            • 1796
            Paul
            I just did one off the car for a friend. Replaced the side yoke seals and Pinion seal in about an hour. Checked it before and after with a dial TW.
            Use SKF/CR seals and be sure they use #2 or equvilent on the splines. #271 red on the nut and I stake the nuts as well.
            Granted on the car may take longer and you won't get the side yoke seals done.
            • Paul L.
              • November 1, 2002
              • 1414
              Paul
              Thanks Gary. I saw your video at DC; very thorough. Yes, this will be on the car so I am thinking at least a couple of hours. And since the driveshaft is down I might as well do (or have done) the TH400 rear seal and u-joints. Would NAPA be a source of SKF or similar quality parts?
