'72 350 Q-Jet carb gasket thickness? - NCRS Discussion Boards
  • Douglas M.
    • February 25, 2011
    • 55
    the gasket between my carb and manifold appears to be ~3/16" or so thick.
    Is this normal?
    If not, what would be normal thickness?
    Doug
    Re: '72 350 Q-Jet carb gasket thickness?
    Is this normal?
    Doug
    Doug------
    That sounds about right for the GM #3998912 insulator gasket. You can obtain a GM replacement for that very insulator gasket under GM #10069984.
