My wiper and shaft can be dropped down the hole and put into place with pressure on the back end and set where it goes and will run about four or five revs then will pop out and then just lay where it popped out, Now I know this sounds nuts but what if one drilled and tapped the back end of the shaft then set the shaft back in place put a srew and plastic washer in making sure to bottom it out in new threaded hole and leaving a 1/16 gap so it could move on the back side of the pulley housing, would this work, or mess something up, yes I to am thinking of time and no idea of how to reassemble this whole project. Thanks again, Brad.
