Re: Can't Time Engine Correctly
The valves were adjusted as per the guidelines for adjusting the 30-30 solid lifter cams. They are quiet, and I think they are okay. The balancer checked out good when I degreed the cam. It does not want to run well with 8 degrees. It seems better at 12. The engine is very lazy. When you rev it up, and snap the throttle closed, it returns to idle slowly. Should the secondary throttle stop screw be holding the plates open at all? What is the proper way to set this screw? Thanks, Mark
