I have seen two types of decals offered for the L84. One is a peel and stick metallic-looking decal and the other a waterslide decal that is not metallic at all. My AIM doesn't distinguish that I can tell, although it calls for a "Decalcomania" whatever that is. Which one is correct?
1963 360 Hp Valvecover Decal
Re: 1963 360 Hp Valvecover Decal
Tom-----I have seen two types of decals offered for the L84. One is a peel and stick metallic-looking decal and the other a waterslide decal that is not metallic at all. My AIM doesn't distinguish that I can tell, although it calls for a "Decalcomania" whatever that is. Which one is correct?
The "waterslide" decal is the one originally used. This is the type that's referred to as "decalomania".In Appreciation of John Hinckley- Top
- Top
The only problem I've had with the "water slide" decal is shelf life. I had a stock on hand and recently cleaned my covers while doing a valve adjustment. My existing "water slides" had been on for a number of years and were peeling at the edges. When I tried to use some new ones, they all broke up, I could not find one good useable one out of four, so ended up using the adhesive back type. Also, placement with the latter is much easier.
Stu Fox- Top
