Joe:
While studying build sheets for 1978, I've come across a set of broadcast codes called out when a non-FE7 with L82 and P255/60 R15 tires were ordered. Build sheets call out CK (front) and CL (rear).
According to 1978 build sheets, all FE7 equipped Corvettes call out CK (front) and CE (rear) and we have those part numbers as listed in numerous past NCRS threads.
According to 1978 build sheets, all base suspension Corvettes with L48 and P225/70 R15 call out CH (front) and CJ (rear) shocks.
Also in 1978-79, 18 different coil spring configurations (and therefore broadcast codes) were called out that in addition to vehicle weight + option weight, a weighting was assigned for whether the vehicle was to be equipped with RPO QGR (P225/70R15) or RPO QBS (P255/60R15) P series tire.
The AIM for both years call out these Part#s:
I'm drawing the conclusion that the FE7 rear shock 4984578 is the CL broadcast code when P255/60R15 tires were ordered with L82. These same vehicles were equipped with GM# 4984577 front shocks (CK). As a result, 1978 Corvettes were equipped with two different heavy-duty shocks and by 1979, only one was used when FE7 was ordered.
When FE7 was ordered with either engine configuration, it called out the CE broadcast code and 22012402 was installed.
In this analysis, broadcast codes called out on build sheets are driving this analysis but I'm curious what your database shows, of which you have referenced in previous threads on the discussion of FE7 threads.
Below, I've included two snippets from 1978 Pace Car build sheets. The first is VIN 2324, non-FE7 with L82 and P255s. The second is VIN 2212 with FE7, L82 and P255s.
- For 1978 FE7 front shocks, AIM specifies GM# 4984577
- For 1978 FE7 rear shocks, AIM specifies GM# 4984578
- For 1979 FE7 front shocks, AIM specifies GM# 4984577
- For 1979 FE7 rear shocks, AIM specifies GM# 22012402
