How would this part judge? (new Long Island exhaust extensions) - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1322
    Has anyone else seen these? I just received an email about them. Looks like Long Island has a supplier now that makes MAGNETIC exhaust extensions.
    The 67 TIM/JG says that "most have a part number", yet the part from LI doesn't.
    How would these judge?
    Chris Enstrom
    2011 Z06, red/red
  • John M.
    • January 1, 1998
    • 813
    Re: How would this part judge? (new Long Island exhaust extensions)
    Chris,
    I got that also. I have a 65 and the manual for that car says there is no part number so I guess one does not fit all.
    If you go to Corvette Central they have them with the part number. Confusing.
    John
    • Gary B.
      • February 1, 1997
      • 6979
      http://www.parts123.com/parts123/yb....ort~1~cadeikba
      Chris,
      It really depends on what judge you get and whether they know about the part # vs. no part number issue and what they think of that issue. There are lots of postings on the DB that claim there should be no part number on tips used in production. But I believe several of the mid-year JGs still say there should be a part number. If you get a judge who goes by the JG and you have tips w/o a part number (even 45-y.o. original tips), I think you're going to take a deduct. On the other hand, if you get a judge who has read the DB postings and is convinced there should be no part number, then that judge may take a deduct for tips that have the part number, regardless of the what the current JG says.
      Gary
      • Tracy C.
        • July 31, 2003
        • 2739
        Originally posted by Gary Beaupre (28818)
        Chris,
        It really depends on what judge you get and whether they know about the part # vs. no part number issue and what they think of that issue. .... that judge may take a deduct for tips that have the part number, regardless of the what the current JG says.
        Gary
        Gary, If a judge takes a deduct for a component that is "as described" by the JG, I think the owner should elevate the issue to the event Judging chair or team leader. In my opinion, the burden of proof is on the judge to convince the National team leader to change his JG in such cases. Rignt or wrong, the owner should not be penalized for abiding by the book.
        tc
        • Russ S.
          • April 30, 1982
          • 2161
          The latest 66 judging guide says NO part number. Previous 66 JG said with part number.
          • Chris E.
            • November 3, 2006
            • 1322
            tc
            Tracy,
            So that brings up an interested problem with this particular part for my car.
            The 67 JG right now says something like "many tips have part numbers". It sort of implies that not ALL tips have part numbers.
            In Regional judging, I took a 1 point hit because the tips were not magnetic. That item isn't mentioned in the judging guide anywhere.
            So, given that the new part available from Long Island is magnetic BUT doesn't have the part number.........would I get my point back?
            I think I would. I could say "the book says MANY tips have a part number, it doesn't say ALL tips have a part number".
            Seems reasonable to me, but I wanted to run it past you guys first.
            Chris Enstrom
            2011 Z06, red/red
            • Gary B.
              • February 1, 1997
              • 6979
              Tracy,
              Chris,
              The deduct for non-magnetic is an example of where the judge knew something that wasn't in the JG. I think he/she was correct taking that deduct. But certainly not all judges would have taken a deduct for something not in the JG.
              And sometime within the past 6 yo 8 years, I'd guess, judges were taking deducts if the tip held a magnet, since they (incorrectly) concluded from that test that the tips were not stainless.
              Based on the "many tips have part numbers" phrase, I see no way a judge could take a deduct for tips either with or without part numbers.
              I am definitely going to purchase a set of the new LIC tips for my '66, since the '66 JG is now unequivocal about there being no part numbers. I think the '67 JG may have the same language some day, but I won't predict when that will happen and I wouldn't bet the farm on it happening for certain.
              Gary
              • Gene M.
                • April 1, 1985
                • 4232
                Chris,
                The deduct for non-magnetic is an example of where the judge knew something that wasn't in the JG. I think he/she was correct taking that deduct. But certainly not all judges would have taken a deduct for something not in the JG.......................
                Gary
                I suggest one look at this from the owner's perspective. The judging reference manual say the word "appears" in the evaluation of pieces on the car. No where is there a reference as to metallurgical verification. Use of a magnet is not a visual evaluation.
                I suggest if one judge cannot distinguish stainless steel 420 grade from 304 grade or carbon steel by looking at it then he is not qualified to make a deduction.
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Gene,
                  I'd say it's a whole lot easier for those of us who are non-experts to use a magnet to distinguish between the two alloys.
                  Gary
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    Gene,
                    Gary
                    That is not the point. If the paint finish "looks" like lacquer but it is actually enamel or urethane it is judged ok. A judge does not pull out a spectrometer and verify it as not being lacquer.
                    The part has to only "appear" per our judging standard to be as original. And if it appears as original then it is no deduction. Do you see what this means to an owner? Are we going to judge everything per the reference manual or select and choose?
                    • John D.
                      • December 1, 1979
                      • 5507
                      Many of us have boxes of NOS midyear exhaust tips in the blue/white box.
                      Truth of the matter is they are far from being correct for judging.
                      When my 63 was re-restored I was in a bind for NOS exhaust extensions. The NOS ones I had were ALL wrong. Ended up getting my beat up ones restored. Highly unlikely you will ever find NOS correct ones for the early midyears.
                      Now I know nothing about the new repros LI is making. I imagine they are pretty nice though. JD
                      • Dick W.
                        • 10483
                        Guess that I am not qualified
                        Dick Whittington
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          Not to beat a dead horse, but until the National Judging Chair tells chassis judges to stop using magnets to test for SS brake lines, exhaust tips, etc., I will continue to use one, at least until I can distinguish among stainless steels without one.
                          But I do understand your point about "appears to". That's partly why I'm very uncomfortable about judging paint, hence my strong reluctance to ever judge exterior.
                          Gary
                          • Tony S.
                            NCRS Vice President, Director Region VII & 10
                            • April 30, 1981
                            • 969
                            Hey Chris. Do the LI extensions also have a seam?
                            Tony
                            Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                            Original member of the Kansas City Chapter, est'd 07/11/1982.
                            Member: 1965 and 1966 National Judging Teams
                            Judging Chairman--Kansas City Chapter.
                            Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              Tony
                              Tony,
                              According to the LIC website, yes they have a seam.
                              Gary
