My question is about the 3461 AFB carburetor and it's calibration compared to the 3269. The 3461 Carter mounted on my 1963 stock 300hp car will not idle down below 6-700 RPM with the throttle blades closed. I have been working on this trying to figure out if there is a problem within the carburetor. The primary and secondary throttle blades are adjusted good in the carburetor bores.
This 3461 carburetor is also used for the 340hp solid lifter motor so the calibration seems generic to both. I noticed two small holes in the secondary bore just below the secondary air valve weight and my car is pulling air from here, when I squirt carburetor cleaner in this area the car stumbles because vacuum is pulling around the secondary shaft finding these holes.
Can anyone tell me if the 3269 Carter uses these holes and why they are there. The 3721 does NOT use these holes and in 64-65 the afb is used exclusively for the 300hp motor.
This 3461 has calibrated vacuum leaks for the choke hot air circuit and the PCV system. This, (I believe) along with the holes in the secondary bores in the location stated above provide the needed air for the solid lifter engines while maintaining the correct throttle blade position at idle. It's seems to be a bit to much for my 300hp engine at idle thus the idle condition I am experencing, this engine pulls 19" vacuum at idle..
All comments are appreciated, are there others with 3461 or 3269 on a 300hp engine that experence the idle condition I have.
Sorry for the long post..
