Re: 3269 3461 AFB Carter Carburetor
I think we are all convinced that it wasn't the drilled passages over the secondary throttle shafts causing your problems, but out of curiosity, i dissassembled my 3460S dated J2, to see if it had the holes. sure enough, it did, so it can't be a 340 hp thing. One hole is not drilled completely as where the drill bit broke through to the shaft bore, it just barely broke through leaving a small opening to the shaft. The other side was more completely drilled.
The original purpose of the holes is still unknown but apparently not a functional requirement.
