62 - 3 lower radiator seals - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    I am looking at the AIM section 11, sheet 4/5 where it shows cementing the lower radiator seals.
    My questions are:
    1. Was the cement the standard yellow weatherstrip cement that was brushed on?
    2. Was the cement put on the radiator supports or just on the body fiberglass as I show in my picture with the yellow?
    Tony
  • Erich C.
    • January 31, 2007
    • 137
    Re: 62 - 3 lower radiator seals
    The triangular end seals on my '62 only appear to have been glued to the radiator support with the edges resting against the inner fenders . The end seal in the photo is not original ( p/s is original ). I had replaced it many years ago but I know I installed it the same way the old one was removed. The gaps/ misalignment is because the fiber glass is damaged. If you look at the photos with the center straight seal peeled back you will see the yellow spot which is the adhesive.
    • Anthony P.
      • June 27, 2010
      • 485
      Thanks Enrich. Those pics are very helpful and I can see exactly where everything goes.. There were no seals on my car when I got it, and any glue was cleaned off.
      Tony
