my tach has a red line of 6300 rpm-my car came with a 427-390hp engine and powerglide trans.I thought the redline was different for this car?
67 tach question
Re: 67 tach question
Yellow line should start at 5700 rpm, red should start at 6000 and end at 6200- at least for manual trans. This 427/390 automatic says it was top flighted, so I'm guessing it's the same for auto. I've never heard of a 6300 redline.
- Top
Mark -
Tach has been changed; the one you describe was only used on L-71's, L-89's, and L-88's.- Top
Hmmm, with the 80 lb oil pressure gauge, it may be that the entire instrument cluster was changed.....?
There is a white label with red letters on the backside of the cluster, about 3"W x 1-1/2"H with a 2 letter designation in large font then smaller font description. The cluster pictured from a L71 435HP has the 6500 RPM tach and 80 lb oil gauge.
"LB" is for L71 and other solid lifter engines which use the 6500 tach & 80 lb oil gauge. I'm told "LA" is for standard tach and 60lb gauge. I am told "LC" is another code but I am unsure of it's application. Maybe speed warning buzzer option?
The rear speedo/tach cover also has a date code. It may tell you if there is a major delta between car build and cluster build.
Rich- Top
This is a cluster sticker "LC" for a 427/390 NO speed warning option. Red lettering. Its for an April 10 build date coupe. 60# oil pressure.
LA = base engine
LB = L71 L88
LC = L36 L79 L68
I don't know the designations for "Speed Warning Option" I believe the tag will be green lettering.- Top
From an early licorvette catalog.
RED LA 5300 60 300 #6457982
RED LC 6000 60 350 #6457985
RED LC 6000 60 390 #6457985
RED LC 6000 60 400 #6457985
RED LB 6500 80 430 #6455364
RED LB 6500 80 435 #6455364
GREEN LG 5500 60 300 SPEED WARNING #6458840
GREEN ?? 6000 60 350 SPEED WARNING #6459496
GREEN ?? 6000 60 390 SPEED WARNING #6459496
GREEN ?? 6000 60 400 SPEED WARNING #6459496
GREEN ?? 6500 80 430 SPEED WARNING #6459495
GREEN ?? 6500 80 435 SPEED WARNING #6459495And when you get the choice to sit it out or dance
I hope you dance
- Top
Stephen, Coincidentally that cluster was dated 44 years ago yesterday.
Ray, Too bad the latest catalog doesn't have that info, at least not apparent when I looked.
Rich
p.s. Good info in this thread.
I remember searching for this reference material 5 months ago and couldn't find it in the archives.
- Top
Anybody out there that has a 67 speed warning option cluster that would post the cluster sticker data along with engine type???- Top
Mark,
If you have a 66, the 80lb oil pressure gauge would be correct with a 390 HP. For 67 with 390 HP, the gauge would be a 60lb.
As mentioned, your tachometer is incorrect for a 390 HP though.- Top
