I have one usable (Left Side) exhaust manifold for my 60 and will be buying a repro Right side. I need to buy the stud set that attaches the exhaust to the mainfold.
I saw in an earlier thread that the studs from the regular corvette vendors are not long enough on the right side, i.e. the info in the thread said they need to be somewhat longer than 3" and the ones from the vendors were somewhat less that 3".
Does anyone have recent experience with getting correct length and configuration for the studs on the Right side to fit with the heat riser? Also, correct Nuts?
Also, most everyone sells a stainless steel set, and I see that Corvette Central also sells a steel set. Is the strong recommendation to use SS even though there will be a hit when judged?
Don
Don
