I bought a complete interior kit from Al Knoch back in the early 90's but didn't try to fit the door panels until last summer. They don't seem to fit. The problem is the hole for the lock shaft appears to be high, doesn't quite line up. High by maybe 1/4".
Has anybody had a similar issue with door panels of this vintage from Al Knoch. I'm wondering/hoping there may be something I'm overlooking. It seems the panel either isn't seating on top of the door completely or they are defective, dimensions wrong... I looked at both ends on the top of the door, the panel appeared to be bottomed out to the door...
When I compared to the originals I noted the top contour of the Al Knoch panels were shallow by about 1/2" in the center. The Al Knoch panels are a bit flatter than the originals. I don't know if this is the problem. I may attempt to measure from the center of the lock hole on the original panel to the top of the panel, compare to the originals, once I get the car out of storage.
Has anybody had a similar experience, hopefully with a solution?
These are deluxe panels.
but somewhat understand after a long period of time, but still think they should replace bad one as it didn't get bad by sitting in box for years. If anything just for customer satisfaction and future recommendations.
) and I bought a set and thought the quality was excellent. I still have them on one of the gold cars and an NOS GM set on the other. Both have withstood NCRS and Bloomington judging with no deductions (but that was then) I don't know if John's is still around, but his 69 panels seemed to be the best thing going at the tme.
