62 Correct upper radiator hose - 3788192 - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    RE: Correct upper radiator hose, 3788192, for a 1962 340hp
    Which hose is correct, top or bottom pic?
    I thought that the top hose with the white stripe was correct, however,all of the hoses that I have received/looked at (Paragone, Zip, Corvette Central) that state "correct", do not have the white striping/numbers along the length.
    Should the stripe be on the hose?
    If the top picture is correct, can anyone recommend a good source for a correct upper radiator hose, 3788192, for a 1962 340hp?
    Tony
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 62 Correct upper radiator hose - 3788192
    I don't think either is exactly correct, but the bottom one is far more correct than the top.
    • Anthony P.
      • June 27, 2010
      • 485
      Mike,
      Any idea who sells the most accurate hose?
      All of the vendors I found seem to have the same lower picture.
      Tony
