would it be better to use NOS T-3 bulbs or buy reproduction ones for flight judging?
NOS VS Reproduction
Re: NOS VS Reproduction
Flight Judging is all about minimizing the POTENTIAL for deductions, in my mind.
With that, I would get a brand new set of repops and put them in. The WORST you'll get is a 3 point deduct for DOT repop headlights.
If you put ORIGINAL T3s in, you could completely fail the 25 point line item in the Ops section for headlights. That hurts a lot more.Chris Enstrom
2011 Z06, red/red- Top
If the NOS bulbs are truly 'old, off the shelf unused stock' they may or may not match production style lamps. If they do match and are unused I would expect they'd be worth their weight in gold and be comparable to the $600 air filter.
Used production bulbs often carry a condition deduction due to discoloration of the lens.- Top
Not to mention one runs the risk of those NOS or used original bulbs burning out every time they are powered up.If the NOS bulbs are truly 'old, off the shelf unused stock' they may or may not match production style lamps. If they do match and are unused I would expect they'd be worth their weight in gold and be comparable to the $600 air filter.
Pete if you did not receive a deduction for the T-3 reproduction bulbs you got lucky. There should have been a deduction. Unfortunately, since I don't do exterior I don't know the points quantity, but it has been posted on the board in the past. I believe the deduct should be the same for C2 or C3 reproduction bulbs.Terry- Top
Lyndon,
I talked with Lectric Limited last year about repro T3 bulbs for my '66 and I was told that by federal law Lectric Limited had to put the DOT making on them.
Gary- Top
That's true of MANY reproduction parts... If they're made & sold today, they generally have to meet current guidelines.
You'll find clear plastic covering the slots on reproduction seat belt buckles due to regulations that safeguard against possible metal to fabric fray. Expect the belt fabric material to meet current tensile strength requirements instead of the 3500, 5000, or 6500 lbs that was in effect when the original belts were built.
The list of changes that are detectable in reproduction vs. original parts due to Federal lawmaking and regulation is LONG. That's reality!- Top
- Top
I agree. Plus, I've found the repos are somewhat brighter than the originals and so are better for night driving.Flight Judging is all about minimizing the POTENTIAL for deductions, in my mind.
If you put ORIGINAL T3s in, you could completely fail the 25 point line item in the Ops section for headlights. That hurts a lot more.- Top
The only way that you will lose the 25 point total is for all of them (4) not to work.- Top
