Can someone please give me the outside diameter of the thick flat washer (103343) used on the bottom of the front engine cross mount to frame tower bolt, between the bolt head and lower rubber cushion. I believe the top washer is 1-3/8 OD. Thanks in advance.
C1 front engine mounting
