I am restoring my 57 and before I get into rebuilding the engine I have a few questions.
1) If it requires boring, what pistons should I use?
2) Should the original rods be used? Rod bolts?
3) I want to keep it fairly stock with hydraulic lifters and cam. Who makes a replacement cam and lifters? Part Numbers??
4) Anything special about rebuilding the heads? - Seals and etc?
5) Higher pressure oil pump?
6) What Timing Chain manufacturer?
7) Gasket set supplier?
This car will never be raced or anything like that, so original horsepower will be fine!
