I am having trouble finding a upper dipstick tube for a early 56 #199. The one that was on the car is mutilated and leaking and the one I have for a 57 hits the manifold. Maybe I need a pic. Any ideas Thanks Ed
Upper dipstick tube source 56
Re: Upper dipstick tube source 56
Ed -
Right side dipstick into the oil pan, or left side into the block?- Top
Ed------
The original tube for your application was GM #3721928. Unfortunately, it was discontinued in July, 1973 and replaced by GM #3732488 which was used in PRODUCTION for 1957-64 Corvettes. I do not know how the tubes differ.
The GM #3732488 is now GM-discontinued but, if it will do for you, your dealer should be able to locate one in dealer stock somewhere.In Appreciation of John Hinckley- Top
Ed,
Here are photos of three 3732488 tubes (1 NOS, 2 used).
How close do they compare with your original tube?
The overall length (straight line measurement) is about 8 13/16". The measurement from the "stop" to the top of the tube is about 8 1/4" measured along the curve. Overall length along the curve is about 9". My parts catalog describes the tube as follows:
8 21/32" O.L. (curved).
There is a NOS 3732488 tube currently on Ebay. It is NOT mine.
Which tube do you have?
56 Corvette (1st design) GM # 3718206 (14 1/2" O.L.) w/clamp (oil pan mtd.)
56 Corvette (2nd design) GM # 3721928 (8 3/4" O.L.)
Dave- Top
Ed,
Believe it or not all 3 tubes in my photo are the same part (GM # 3732488), same length, etc., except that the bottom end of the used tubes tend to get bent a little at the stop just from checking the oil for many years. I have at least 25 to 30 various used and NOS dipstick tubes as well as that many dipsticks if not more.
Dave- Top
Well that bend at the bottom is what I needed to get the proper fit. I used the tube bender and modified the tube I have to make it fit. Thanks for the help the pics were great. The tube lenth is correct. Ed- Top
Ed------
That slight bend at the bottom might be the difference between the 3721928 and the 3732488.In Appreciation of John Hinckley- Top
Joe,
The two used tubes in my photo are from a 1960 & a 1962 Chev. truck, GM # 3732488 according to the parts catalogs. I have another tube just like from a 1959 Chev. truck ("F 7 21 M" stamping on pad), same bend.
I really believe the bend is caused pushing up against the dipstick when reinserting it over a period on many years.
The 3721928 tube was also used on 1956 Chev. trucks Ser. 6-8 (8 cyl.)
Enclosed are photos from my 1961 Chevrolet truck parts catalog.
Dave- Top
Dave------Joe,
Dave
Yes, I realize that the tubes you have pictured are the GM #3732488. However, Ed mentions that he needed to create a bend like that in his 3732488 in order to make it fit properly for his 1956. So, I'm just speculating that the 3721928 might have had that slight bend as a design feature.In Appreciation of John Hinckley- Top
