Looking for a little help before I tackle this weekend's task. The replacement radiator in my 66 SB roadster has sprung a leak around the tube that goes to the upper radiator hose. I'm not quite ready to make the leap to a DeWitt repro radiator and just want to have this one repaired.
Here are the questions - I've not removed a radiator before -
1) is it as easy as it looks? Remove hoses, remove bracket across the center top of rad, remove a couple of bolts and slide it up and out?
2) are there any attaching bolts at the bottom or does it simply rest on rubber mounts? If there are rubber mounts, should I replace them? (btw - best guess is that this rad was installed by original owner about 21 years ago)
3) do I need to remove the hood for clearance/access?
Thanks in advance for advice and tips on this task.
Cheers,
Cheers,
