I have my 60 body on it's side and have started cleaning the underside. Picture 1 below is what I started with, although I had done some wheel well cleaning already. Picture two show the area above the spare tire well after cleaning.
Picture three is a close up and you can see that there is still some crud that is in the fiberglass grain. I have used various cleaners and chemicals (409, simple green, acetone, brake cleaner, laquer thinner, and Cap't Lee's stripper) and this as clean as I can get it without sanding or something.
How clean does it need to be for judging purposes?
Would any sanding be a big NO-NO? I have some areas along the outer edges of the underside, i.e. under the quarter panels, where the glass seems to have taken a beating, i.e. has a weathered look and rougher surface.
Should I sand this or leave it alone?
As always, thanks for the words of wisdom.
Don
Don
