What crank is correct for a 427, 4351 2 bolt main block? - NCRS Discussion Boards
  • Charles S.
    • March 1, 2005
    • 31
    Looking for help identifying which crank is correct for the 427, 4351, 2 bolt main, 67 corvette block? Does it have a part number stamped on it, if so what is it? Thanks. Chuck
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: What crank is correct for a 427, 4351 2 bolt main block?
    6223 is one number use on 427 forged cranks
      Charles------
      The most common 427 crankshaft forgings of the period were 6223 or 3856223. There were a few others that may have been used, but these are the most common.
      • Charles S.
        • March 1, 2005
        • 31
        Charles------
        Joe, thanks. That's the number I'm finding also. Chuck
        • Robert K.
          • June 30, 2001
          • 212
          Chuck,
          I thought that all 427/435hp (4351) blocks were 4 bolt mains (not 2)? Am I incorrect?
            Originally posted by Robert Kerestes (36438)
            Chuck,
            Robert -
            The 3904351 block was produced in both 2- and 4-bolt versions; the wording in the original post ("427, 4351") refers to the 4351 casting number, not 435hp. The 435hp version (L-71) was indeed a 4-bolt block, and the 390 and 400hp versions were 2-bolt blocks.
            • Wayne M.
              • March 1, 1980
              • 6414
              Pic of the 6223 casting number on a 2-bolt '65 961 block, in post #17 of this old thread.
              https://www.forums.ncrs.org/showthre...crank&uid=2810
              • Charles S.
                • March 1, 2005
                • 31
                Thanks! Chuck
