1957 Headlight/Parking Lamps/Instruments - NCRS Discussion Boards
  • Edward L.
    • 278
    I recently finished wiring my 1957. I have dim headlight, parking lamps, and instruments that will flicker when I turn the headlight switch. I have checked all grounds and connections at least twice, tried different headlight switches, same result.
    This is a non radio/ non courtesy light car. My grounds consist of battery to starter, valve cover, light switch, and rear bumper bracket.
    Did the non radio cars use any of the ground straps typically found in radio equipped cars?
