66 L72 instrument cluster info - NCRS Discussion Boards
  • Carl B.
    • March 1, 2007
    • 89
    would like info on rear of instrument cluster. broadcast number and speedo and tach numbers for a 66 L72
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 66 L72 instrument cluster info
    Should be exactly the same as this tag on the back of the last 396 (Aug 2nd 1965). Cluster ink-dated July 26 1965.
    The only difference in the gauges would be the scale and color zones on the temp, and the endpoint (240 w/no color for '65, vs. 250 with color zones, for '66).
    • Carl B.
      • March 1, 2007
      • 89
      the reason I ask the broad cast code is LD with the speedo and /tach #'s not the same on my car as your photo
      • Pancho T.
        • July 31, 1993
        • 238
        all of the '66 L72 cars that I have seen have the LB label on them
        • Wayne M.
          • March 1, 1980
          • 6414
          I notice Long Island Corette lists many dash cluster stickers; unfortunately, they don't give the letter codes for the various speedo and tach combos.
          Can you tell us what these two latter part #s are on your LD sticker ? Maybe we can work backwards to what engine and option(s) this applies to.
          • Stephen L.
            • May 31, 1984
            • 3148
            This issue came up a few months ago. Do an inquiry on the subject and I believe you'll find a fairly complete list of the numbers for the various combinations
            • Robert G.
              • May 31, 1990
              • 429
              The limited information I have indicates that LD would have a tach redline of 6000 rpm.
              • Carl B.
                • March 1, 2007
                • 89
                speedo 6455367W / cluster 6457983 /tach 6412222W I tried a search no luck tried different combo's came up empty
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  6455367 is the standard '65-7 speedo w/o '67 speed warning (U15).
                  6412222 is the 5300 RPM redline (base engine in '66-7).
                  6412522 is the 6000 redline ('65-7).
                  From P&A30B Corvette catalogs, Gr 9.750 and 9.761.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Carl, Here's that (67) thread from a while ago, it may help....Rich
                    https://www.forums.ncrs.org/showthre...=7409#poststop
                    • Carl B.
                      • March 1, 2007
                      • 89
                      mystery solved thanks looks like my car might be one of those 15000 66 big blocks running around
