In 2004 I did a frame up restoration on my 60' and replaced the original FireStone tires with Diamondback Radials. Now seven years and 4500 miles later one of the white walls has seperated. I called Diamondback and was told to replace all four tires because of their age. Is 6-7 years the shelf life of radials?
Tire life in years
Tags: None
- Top
Re: Tire life in years
Rich, Being in the automotive trade tire life can be 5/6/7 years as rubber ages they can dry rot before there useful life with most corvettes, and who knows there maybe a date code on the tire that may even show them to be older. sometimes they sit in warehouses and then the tire stores before there sold.
A few other factors to consider is white wall cleaners, sunlight, and humid climates shorten there life to.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Knowing what a blow-out can do to a fiberglass body SHOULD keep you at the short end of the spectrum.
5 yr. old tire + 45 m.p.h + pothole =- Top
Richard, I'd change them all. I had 5 year old radial tires on my 70 when I brought it to the painter. A month or so later one of the radials blew just sitting there, causing no damage. I didn't have replacement wheels, and since I only lived a few miles away, I foolishly thought I could at least get home with the three other radials and a spare.
Can you guess the rest? Another tire blew 2 miles from my house, shredding the last original rear quarter panel, with brand new paint. Fortunately my painter is a wizard, and with lacquer paint and all the broken pieces you cannot tell there was any damage today.
But the moral of the story is, why risk it? Good luck.- Top
Watch this video.
- Top
I'm sure plenty of people have had blowouts with old tires, but I've only ever had sidewall defects on brand new tires. Given my experience and yours, I'd go ahead and replace all four but NOT because of age, rather, I'd be thinking to myself the other three may be prone to the same damage. In fact, I'd get a different type or brand next time.- Top
Here's a link that I had saved to determine the age of a tire.
http://www.tirerack.com/tires/tirete...2&AID=10398365&- Top
Thanks for all of the information and advice. I have elected to replace all four with new Firestone whitewall radials from Diamondback. For some reason I thought that newer tire technology and radial design had eliminated the aging factor.- Top
- Top
Rich,
There's no set life for tires. I have tires that are 37 years old, and they function fine. I also have tires that have failed in two and three years. Tire life depends on the construction of the tire, the quality of the materials, the workmanship, how it's used, the temperature and environment that it's exposed to, and how well the inflation pressure is maintained.
Below are some pictures of a classic belt separation. There is a low spot on the left and raised bump on the right. This tire was recently way overloaded while it was overinflated. A sure recipe for tire destuction. The tire is 8 years old. It will blow if driven very far, but it was easy to detect in the behavoir of the truck.
Over the hundreds of tires that I have owned, I have never had one blow, although I've had belt separations occur on the road. I don't have very old tires on anything that I drive fast, and the tires on those vehicles are expensive tires. I also don't have very old tires on any of the classics that can get damaged by a tire failure.
Paul- Top
Rich,
PaulDick Whittington- Top
