Hi, I have a 66 L79, the crank pulley has a numbeer of 3850838 BG and the judging guide has that number but no BG after the number, the water pump pulley is the same way with a 3890419 CT, I ordered a set of GM restoration belts and they are to small using these pullies, I have a crank pulley that is 3744043BA that is smaller and when I put that pulley on both belts fit. what do I need to do to fix this? Thanks for all your help, Terry
