If there is no thread sealant used, will there be any leaks from the threads?
Assuming that no sealant is used for better continuity, then wouldn't it also be necessary for the intake manifold to head bolts and head bolts to engine block not to have sealant on threads as well. This would certainly make the ground strap on the throttle linkage vital.
Please advise.
My temp gauge works intermittently. Not long after the engine reaches op temp, the gauge drops to zero. It will occasionally come back to its normal reading.
Temp sender wiring, gauge have both been checked, so the problem lies with the sender.
Please advise.
To my knowledge, when threads are jammed together and torqued, there SHOULD normally be metal-to-metal contact along the pitch diameter, I reckon, of the threads, and only along one surface where the clamping force is occurring. How does that sound? Any sealant should only fill the remaining void at the opposite sides of the pitch diameter, and down to the root diameter, up to the crests.
