1981 Aluminum wheel de-coding - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    I assume aluminum wheel numbers are not judged since they can't be seen without removing wheel. I am curious, however, about the numbers. My '81 wheels have the following numbers:
    • Cast-in: KH or KHN 101072
    • Cast-in: 14018395
    • Stamped: eight digits
    • Stamped: four digits, starting with P
    • Stamped: four digits, starting with S or 2 (not a clean stamp)
    Questions:
    Are the cast-in numbers the correct part numbers?
    Where is the date captured in the stamped numbers?
    Thanks a lot,
    Charlie
