Can someone please watch this video to tell me if they agree with my conculsion that the rear drivers side wheel bearing has failed.
I was at an NCRS Chapter meet last week and after about 40 miles of driving around 70 mph I heard a grinding noise coming from the rear drivers side of the car.
I had the car loaded on a flatbed tow truck and got it home.
The noise seems to be coming from the rotor hub. It is not coming from the half shafts I believe and the halfshafts have no play in them at all.
I have heard these are real strong bearings and rarely fail. I doubt they have ever been replaced or even greased. A mechanic at the meet drove the car and thought if it was a wheel bearing the noise would change if the car was driven in a low speed slalom pattern. It did not change as we shifted from left to right.
My plan is to get rebuilt trailing arms with rotors from Barird's and replace both. Should I also hand the half shafts rebuilt and replace all the suspension rubber ?
Once replaced, is there a good way to grease them regularly ?
Anything else I should change while I am in there ?
