I need help getting my vacum advance back where it should be on the right vacum port on my qaudrajet.Should it be hooked to the front port on the driver side above the idle mixture screw or should it be hooked up to the vacum port that sticks out through the choke area. And I don't know if it should be hooked up to full vacum at idle for timing or vacum under acceleration. The biggest thing I don't understand is how it should affect my vacum advance at idle after I set my timing with it plugged off and then hook it back up to my distributor. Right now I have it hooked up to the port in the front of the carburetor and their is no vacum on that port when idling.Much thanks for all help.
