Midyear BB vs SB Fuel Lines - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi guys,
    Can someone tell me if there was a size difference between midyear BB and SB Fuel Lines. That is, were BB fuel lines 3/8 and SB 5/16 or were both 3/8?
    Dave
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Midyear BB vs SB Fuel Lines
    Originally posted by David Schutzbank (50698)
    Hi guys,
    Can someone tell me if there was a size difference between midyear BB and SB Fuel Lines. That is, were BB fuel lines 3/8 and SB 5/16 or where both 3/8 ? ....
    Dave --- both same size; 3/8" O.D.
      Wayne and Dave------
      I agree.
      • Michael H.
        • January 29, 2008
        • 7477
        Hi guys,
        Dave
        Dave,
        Joe and Wayne are correct on the size. There is a configuration difference between small and big block though. The forward/fuel pump end of the pipe is shaped differently.
        • Michael F.
          • June 4, 2009
          • 291
          Originally posted by Michael Hanson (4067)
          Dave,
          Don't the BB and HP small blocks use larger fuel lines than the low hp,at and after the pump?
          • David S.
            • August 9, 2009
            • 595
            Hi guys,
            Thanks for the replies! I appreciate it.
            Dave,
            Michael, I know the differences in configuration of the two lines. My question generated from having a bunch of original fuel line clamps. Some are 5/16th the others are 3/8th.
            Maybe this explains what I'm trying to figure out. Did small blocks use 5/16th hose clamps because the hose at the fuel pump was smaller than on big blocks?
            Dave
            • Michael H.
              • January 29, 2008
              • 7477
              Dave
              David,
              The size of the long fuel tank to fuel pump line and the hoses/clamps used at each end of that line would be the same for both small and big block.
              Fuel lines from the fuel pump to the filter/carburetor on big blocks do not use clamps or hoses.
                Michael-----
                Not that I am aware.
                • David S.
                  • August 9, 2009
                  • 595
                  David,
                  Right. Now I'm referencing the rubber hose that goes from the gas tank to steel fuel line (in the back) and the rubber hose that goes from the steel fuel line in the front to the fuel pump. Both hoses use two clamps each.
                  -Dave
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    -Dave
                    David,
                    Yes, that's correct. And the size is the same for both small and big block.
                      -Dave
                      Dave -
                      Those main tank-to-pump hard lines and the connecting rubber hoses at each end were 3/8" from mid-'56 through at least the C3 era, on everything from the base 265 to the L-88. Prior to mid-'56, they were 5/16".
                      • David S.
                        • August 9, 2009
                        • 595
                        Dave -
                        Thank you John!
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          Thank you John!
                          I answered your question. Twice. What was wrong with my answer?
                          • David S.
                            • August 9, 2009
                            • 595
                            Nothing! Thanks for your help!
                            -Dave
