I've searched for past posts and found them all interesting. I came across a NOS # 40658 . It is a type that has screws on the bottom with a metal tab that had the number on it. All others are the pressed on type. When did the pressed on start. My car is a March 68 build. Thanks jeff
Correct AC Fuel Pump 40658
Re: Correct AC Fuel Pump 40658
Anything on the casting? Numbers, AC logo? Did it come in a box? If so, there usually is a date of manufacture (for the box) on one of the flaps.Bill Clupper #618- Top
Jeff -I've searched for past posts and found them all interesting. I came across a NOS # 40658 . It is a type that has screws on the bottom with a metal tab that had the number on it. All others are the pressed on type. When did the pressed on start. My car is a March 68 build. Thanks jeff
The crimped pump started in August '66, for '67 model year production.- Top
Thanks again all.there was a pump on eBay with this number.wasn't crimped. It had screws and had a silver tag with the number. Jeff68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
